RSTeclipse97
- 120
- Mar 19, 2008
York,
Pennsylvania
Ok 420a guys heres the 1st ? Ive done some searching but no luck on how the heck to remove the stock fpr 0n a 97 to retain the stock filter and run just the sfmu. The only thing i could find was on 2gnt and it wasnt all that clear to me on what to do,so some assistance would be greatly appreciated.
The next thing i need to know is this, I would like to run say 15psi safely the correct way with the sfmu on a daily basis but beable to run say 20-25psi on occation. What size injectors would you recomend,spring,disc,etc. I also have a safc that i can tune 2 maps with. Is what i want to do possible, by means of switching between two psi ranges and what not. So please give me your suggestions and what has worked for you. I will be getting the sfmu in june so i wanna start gathering up everything else i will need. And if i cant switch back and forth just let me know what set up i can use for any of the above said psi's. And yes i did check out the old threads about this but figured i try to see if theres any new info. Sorry for the lengthy post. Thanks Roy
