Cartech FPR on Hahn kit Oscillates...
kergilman
207
Oct 25, 2007
Portland, Oregon
Well I had read on this forum a few times that these FPRs were shit. So I was not suprised when, after boosted operation, I can park and idle and sometimes my FPR will vibrate at around 2Khz. I just read on cartech.net that adjusting the gain screw valve should remove this "back pressure". I'll try that next time...
They also stated:
5. Fuel pressure oscillates:
Slow oscillation of ~1 Hz can result from the regulator being installed backwards.
Faster oscillation, more like a buzz, but without the noise, is usually induced by a rapid pulsation from the fuel pump. Not much can fix it short of a different brand of pump or a pulse damper. The condition is not harmful at boost pressures of 8 psi or less.
If buzzing is audible, turn the center screw 1/4 turn, and it ususally ceases.
6. Regulator buzzes under boost:
This fault occurs occasionally when fuel pump and manifold pressure oscillations overlap to reinforce each other. Usually, it can be quieted by turning the center screw one or two flats. If it cannot be quieted in this way, return the regulator to us for an overhaul or replacement.
I wonder why Hahn choose to include the Cartech FPR in thier kit...?
Anyone else replace this with something better to regulate the Walbro 255 fuel pumps...?
Looking at the Vortec, I see that it is rated 25-80 PSIG.
Website
Would that be an issue seeing that I set my current load fuel pressure @ 90 PSI...? (Idle @55)
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
