adjusting the timing
bossdogg
Jul 28, 2007
fort worth, Texas
i heard that you could adjust the stock cams and cam gears to run a little faster, how true is that, or should i buy the adjustable cams and cam gears. is that true or ###
You can use a gear on the intake and set it back 4* (generic. All set-ups are different). This will add some overlap and some top end power. I did this on a dyno and gained like 4whp (sorry don't remember the exact number).
You CAN also use a stock gear and just machine the slot to fit your adjustment (which some have done). But at that point, I would just get a good used adjustable.
Some have adjusted both in different directions, for different amounts and claimed it felt like they had more power. IDK, I just know that I had the actual dyno numbers on my adjustment.
MB
    • eclipsemf
