RX-7 injectors
Metapharstic
Dec 17, 2006
Quad Cities, Illinois
OK for some this may be an old subject but i figured i would try to help those that have ben needing bigger injectors and thought about using the RX-7's TII injectors but didnt want to get the wrong type. I read about all the post on this subject and did alot of searching until i came across people that post and were using the right injectors off the RX-7's . Which are the 86-early 87 Turbo cars. They use the low impediance 550cc injectors. That Denso part number is 195510-1370 . I then went to my local Advance Auto parts and checked on a set for the 86-87 turbo RX-7's . Advance had a set of Beck/Rnley remanufactured injectors for 57.00 a piece. So i ordered four for a 240.00 plus tax. The part number for thoser are 155-0234 which cross references with the 195510-1370. The injectors fit perfect and the tab for the wiring harness connectors is correct . All i had to do was was adjust my SAFC. I have my lower honey comb removed and adjusting screw flushed so i richen up the idle with the AFC. I am still tuning and doing pocketlogger runs but mostly i have thigs set up around +30 1K to +15 at 4K on the Lo TH. The car so far is running great and guess what?? No more Fuel cut!! And only 2-3 counts of knock at 16 PSI with 19-20 timing..Hope this helps
Can anyone confirm this?
To read the topic entirely, http://www.dsmsource.com/forums/showthread.php?t=86395
~~ZaK
not the best deal IMO.
Racetronix.com. Look up Siemens Deka, they have the correct spray pattern for our intake. Any size you want 50-60.00 each. 550cc are also available in high impedance too.
Keep in mind, Siemens makes the injectors for accell as well. The post your quoted is for a set to fit a 4g63 fuel rail which the injectors are different that ours and they are low impedance so no they wont work easily.
Terry
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
