egr engine light
cyrez187
359
Dec 12, 2003
kelowna,
i took out my egr but it throws the engine light on ### its not seeing the sensor pluged in, so do i just hook the egr sensor back in and run it to vacuum or what. just to get the engine light off thanks guys
You can try just connecting the solenoid to the wiring harness; no vac lines needed. You should be able to do away completely with the EGR valve and tubing. I've heard that works with 95's.
