93talonES5spd
- Sep 5, 2002
South Elgin,
Illinois
well well, the inevitable happened, my timing belt gave out. i couldnt believe it. one night when i was out with my friends, the rpms stuttered than died. i thought maybe i drained the battery with my system. so i tryed to restart it. it turned over, and over, and over. but nothing. so i got a jump. again, it went over and over. forget it, so i had my buddies and i push it into a parking lot for the night. all night i was thiking of what it could be?? the next morning i get it towed home (it only cost me $5 for 10 miles!!!! thanks AAA). so i go searching. i immediatly think of the fuel pump or filter. nope its getting fuel. then i think of the ignition system. WHOA, its not getting spark. i found it!!!! whoo hoo. after hours and hours of trying to get that stupid ass coil out, it comes out but checks out ok!! damn it. so i thought for sure it was the ignition power transistor. for $130 it better be the right part. i put it in and....nothing
luckily i get to return it. so then i say F--- it!! i take it to the pros. the next day they tell me the news. the timing belt has worn away where the cams arent even moving. #@%#@%#@%#@%. and then the monster blow. the valves are broken and the engines trashed.
so what im saying is if anyone of you guys has a sympton like this, and you dont know what it is, well take a look at the timing belt. it may look like it has teeth on the belt like mine did, but down by the crank, the teeth were worn away to nothing. so have someone turn the car over while you check to make sure that the cams are in fact moving, if not, well, im sorry....its tooo late.
