Talon DL question
mfuz16
A friend of mine has a Talon DL that he just got. He says the 1.8 engine in it is stock and has 180hp. From what Ive seen, they come with more like 130hp stock. I was wondering if there were any special DL's made in 94' (the year his talon is). I have the ESI with 140hp stock and im wondering how a 1.8 stock engine in a talon DL could have that much more hp than my little talon esi. Any info is appreciated, thanks.
Oh and by the way, His talon DL is a manuel transmission. I was thinking that since it was a manuel transmission that the car would have some more power than the auto trans in my car.
Boy, your friend dosent tknow his @ss from a hole in the ground. His mighty Talon DL is a 1.8L SOHC rated at a whopping 92hp!!! With a 5spd it can be a little peppy, but nothing to worry about.
Originally posted by HondaHunter2002
and oh.. if i'm not mistaken it's only an 8 valve also.. 180hp my #$%
Your correct, its only an 8V SOHC. In the 1.8Ls defense... I used to have a 94 Talon DL 5spd. I had intake, exhaust, plugs/wires and it was a pretty peppy car. I beat it down for over 2 years, and I never put a dime into. Those 1.8s run like Hondas.
Originally posted by Antonio_bigbob
but wouldn't the 1.8 win cause it is manual???
wouldn't a manuel 1.8 talon beat and automatic 2.0 talon???
No, the 5spd helps alot, but not that much. The 1.8L has 92 hp for cryin-out-loud!! The 2.0 has 140.
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
