slowmotiongeniu
- 43
- Mar 17, 2004
rochester,
New York
I got a short ram intake on ebay and I'm curious about supporting it in the bay...what has everyone else done? I was sent one straight bracket, about 5 inches long, with three holes in it, and one straight bracket that was bent into an L-shape with one hole in it. Anyone experience something similar? How'd you support your intake for shaking and normal driving?
I had to cut the rubber boot, a little more than an inch had to be taken off for it to even fit at all, and as it is it's a tight squeeze between the washer fluid reservoir and the battery and clamps...anyone else have fitting issues with their install? how'd you solve? anyone else have to trim the boot?
So I need to cut some material off the pipe where it meets the tb so it won't be pressed into the battery tie down. In the meantime, I just put some silicone hose over the battery tie down bar and it sits just fine. I'm glad I did't pay more than $30 for such a lame mod.
