Do I go for turbo or N/A aftermarket parts?
KANGA07
Sep 13, 2002
If I put a turbo kit on gs, does it then become a turbo eclipse and I buy turbo eclipse parts, or do I continue buying non turbo things? What if they deal directly with the turbo, like intake manifold, nitrous, etc. Anybody else have the answer, please help me out.
They are completely different engines. You would still buy things for the 420A engine because you still have that engine. Like LarryD mentioned, you might want to buy a GS-T exhaust, due to it's larger piping.
3 inch. non-turbo piping is 2.5 inch max. stock piping on a non-turbo is 2.25 inches
There is no way a stock turbo exhuast is 3 inches!!. A stock GS-T exhuast would flow better than the one for the GS and RS. I would go with some sorta aftermarket GS-T exhuast. 3 inches. Once you buy a turbo kit, the manifold and everything else realted would be included. If you have a 2G then you have a completely different engine and nothing for the stock 4G63 will work for your engine. If you have a 1G then you can use the stock parts from a 1G turbo.
i was refering to an aftermarket exhaust. stock their 2.5.
