fuel question
MitsuE95GST
103
May 28, 2002
Sumter, South Carolina
I have three questions,
1. What type of injectors does a turbo car have low or high impedance?
2. A friend of mine has a GS and wants my stock exhaust from my GST, will the entire thing fit or just the cat-back?
3. Will a 2G GST stock fuel pump work in a 2G GS car?
Im not sure about the other stuff, but dsm's have low impedence injectors, somewhere in the 2.3ohm-5 range. RX7 injectors have been known to be high impedence.
Im not sure why the hell you would wanna put a Turbo fuel pump in a NA car, it would drown it. The pumps may be the same but I seriously dought it.
RX-7 Injectors will work ..its off a particular year...i forget off hand, but I believe its around 87 or so...the Turbo 2 model had 550 Denso low impedance injector's. I have them in my car and they run great.
I would not put a turbo fuel pump on an NT car.
I don't think the exhaust will fit, i'm sure if you look on the net from various vendors you will see different upgrade paths for NT cars, hence a totally different exhaust.
