Quote:
Originally Posted by spyderturbo007
There is no way for the user to adjust the AFR between the two throttle trigger points. The SAFC-II uses a linear extrapolation based on TPS and the Lo and Hi maps.
so basically it takes the lo-t map and hi-t map and the amount of TPS signal and mixes the maps together to get a # of correction?
