bastarddsm
- 5,762
- 1,691
- Aug 26, 2003
Mendota,
Illinois
Heres a few ideas for you guys to play with. build a 2.4 using a 4gcs and a 4g63 head. I belive this creates a 11:1 compression ratio. then use the cyclone intake with the butterflys working for better lowend torque. switch to a turbo computer and such, it really isn't hard you only have to add 3 wires, and you get the benefit of a knock sensor and being able to burn eprom chips. Keep your n/t trans low gears are your freind with a low torque motor. You guys will never make enought power to tear up a n/t trans. thats what i run in my turbo car and there simply isn't enought traction to break it, and it is just as strong as a turbo. but avoid spinning one tire cause that will cause it to spit a spider gear out into the belhousing. (this is why i have a n/t tranny now)
and this seems like the best thread for me to ask this question. I was reading through some of the older posts. So, this is whats been eating me. I have a 1g head thats been ported/polished. I have the hks 264 intake cam as well, would my vacuum be lower with this combination of mods? My vacuum is only about 5in/hg at 900rpms. I have done a boost/vacuum leak test from the uicp to the manifold and to no luck finding anything that would attribute such low vacuum figures
I have a Cyclone intake manifold with replaced gaskets also. My injector o-rings are brand new and are not leaking. My compression was 190psi in the summer, so thats not an issue. I dont have my cams degreed either, they line up at 8*btdc
thats the best i could get them. Im open to any suggestions, as I want all my previous issues resolved when I get my new shortblock...
