View Single Post
Old 07-27-2005, 06:50 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
TURFNNSURF Offline
Proven Member
TURFNNSURF's Avatar
Tech Posts: 537
Classifieds Rating: 5
Reputation: TURFNNSURF is extremely helpful and trustworthyTURFNNSURF is extremely helpful and trustworthyTURFNNSURF is extremely helpful and trustworthy
Just this afternoon, before all the big thunderstorms rolled in. I took my car out for a run down the highway to test out my Coolingmist setup.
It was 96* outside air temp, 80+% humidity and I have my MBC set for 24psi on pump 93 gas. The coolingmist kit is set to activate at 10psi. I merged onto the highway, found the left lane wide open so I punched the gas. 24psi came on in a heartbeat, the logger showed NO knock all the way to 6500rpm in third and timing was between 18 and 22 degrees. The car felt great, maybe even a little rich yet so I think I might be able to pull a little more fuel out up top.
Our cars respond very well to H2O/Alcohol injected into the mix. BTW i was using the blue windshield washer fluid about 49.5% methanol, 50% distilled H2O and .5% blue dye.
____________________________
Brad
