beat90tsi
- 339
- Oct 28, 2004
pittsburgh,
Pennsylvania
Last week my cooling fan wasn't coming on when it should, I have since fixed the problem.
At the time, I was outside my car and it was idling. When I got in I found the temp needle was on the far right side of the white mark in the center. I immediately started driving and turned both fans on with the AC switch. However now when I drive it I see temps of ~201/204 on the logger during normal driving, it used to be more like 194/197. This happened both during the day and after dark. It seems like a small difference, but I'm concerned about the health of my HG and or head. I guess I could just get the coolant tested for exhaust gas, however my question is how hot was it when I had it that far right? I know nobody can give me an exact answer, but it would be nice to have an idea.
I didn't look at that logger at the time because I was too busy trying to get it back to normal operating temp. The needle is in the same position at 204 as it was at 194, so I would guess it was significantly higher when it was all the way over on the other side of the mark.
Thanks for you help in advance.
Jon
Jon
