Finally installed Pro-Kit and KYB GR2's
Patterson
136
3
Apr 6, 2005
Harrisburg, Pennsylvania
I finally got around to installing my eibach pro-kit springs and new kyb gr2 shocks/struts. Let me just say wow! It is a perfect drop and the car handles great. It absorbs bumps and potholes wonderfully and i couldnt be happier. The installation didn't take too long either. the fronts were a pain but the rear's were easy. I also installed the DIY rear camber kit. that was also easy. I need to install a front camber kit but i'm still shopping around for one. I'll probably end up with the eibach one.
I just wanted to shout out at those confused on what suspension set-up to go after. I am very happy with mine! :dsm:
That is a good daily driver on a budget setup. I essentially have the same set-up on my 1G. Intrax springs with KYB GR-2s. Although the GR-2s are 10% stiffer than stock they aren't considered sport shocks. To me that is fine because I need a somewhat soft ride for daily driving. But the nice drop helps the handling immensely which coupled with the smooth ride makes for a good setup that doesn't break the bank. Add a Road Race rear stress bar to combat understeer and you've got a nicely upgraded but mild mannered DSM.
:rocks: :thumb: :dsm:
Hopefully your GR2's hold up better on your 2g AWD than they did on my 1g AWD with the same setup... the shocks only lasted about 10k
