mitsugsx95
- 707
- 2
- Sep 27, 2002
Illinois
What would you say the ideal ride height is for a 2g gsx setup for autox/road racing. Now I know that autox and road racing are two totally different beasts in themselves, but there is some compromise in the height setup between both. Also, I am just trying to get a general height to start with, as I want to setup the coilovers with corners weights and adjust them accordingly (if i can ever find a stupid place that has corner weight scales
). Would I have to first find out how much the suspension compresses before I can make any adjustments. (I do have a general understading of suspensions, but i am still learning myself)
Secondly, where exactly would you want to measure it from? I was thinking from the center of the hub/ axle nut. Thats how i have it setup now, but its only done by eye and a little measuring (again, no corner weights).
I have D2 coilovers with 9/7k spring rates (504/392lbs/in)
(yeah, i know the 50/50 compression/rebound rates suck
Thanks.
). Would I have to first find out how much the suspension compresses before I can make any adjustments. (I do have a general understading of suspensions, but i am still learning myself)Secondly, where exactly would you want to measure it from? I was thinking from the center of the hub/ axle nut. Thats how i have it setup now, but its only done by eye and a little measuring (again, no corner weights).
)Thanks.
