General Black box ECU install?
96talontso
300
Jul 12, 2011
Edmonds, Washington
I just got my black box ecu and in the package it said that i needed to pull pin 91. Im not sure which pin this is, and why do i have to do it?
Just happen to see this PM'ing someone back... .
It's not pin 91 it's pin 44 for the 98/99 Ecu .
Pin 91 is for a 95 Ecu with other software and tuning solutions.
This http://www.dsmtuners.com/forums/articles-electrical-wiring/391091-ecmlink-nlts-wire-install-setup.html Would be the same but you want to use the clutch switch not cruise control switch and pin 44 obviously (it may need to be pinned to do so) See Here on how to
The car will run fine as it is now you just need the Clutch wire hooked up to run NLTS and 2-step/Anti lag.
I get back to my Email fast, you can just ask me any questions you may have and will get a much faster an the right answer. Just messaging me ;-)
Thanks.
I know this is an old thread, but I haven't seen anything covering if your clutch safety switch is already disconnected. My car was an auto GST the PO swapped to manual but seemed to halfass it. Both manual and auto ecus were left attached. I finally got the car back together again with a new motor out of a 96 GSX and swapped the camshaft sensor only to find out that my ECU was toast causing 2 cylinders not to fire even after I installed a new ICM/PTU. Can I just plug in a Black Box and be able to start the car or should I be connecting something else? Does it need to be tuned first? it's such a mess it's confusing me just talking about it LOL.
But will not having the clutch safety switch cause my car not to fire if I don't have it plugged in?
  • Wanted 6 bolt NT water pipe
    • chrisman287
