1G Tach Not working
JAW91
128
5
Dec 16, 2008
Orlando, Florida
I have a 1991 Talon but it was manufactured in August 1990, the car has an external oil cooler, the TPS is from a 1990 and the Coil pack is from a 1990, the gauges are from a 1991 though and everything works EXCEPT for the Tach. My question is would the tach be the only thing that shouldn't work if you have 1991 gauges in a 1990? Or would none of them work? (It also says its a 1991 on the title and my sunroof clip is the plastic one, not the metal one)
Yes, but like I said though, the gauges are from a 1991. They are in increments of 10, not 5.
Anybody know this? The question is what gauges exactly work and don't work when you put a 1991 gauge cluster in a 1990?
At this point how do you know that's the original engine? We see people stuffing cheap 90 style engines in 91+ cars all the time.
Check the ECU. You want to know what type/part number it is.
Check for the 90 noise filter which should be attached to the side of the intake manifold stay. It couples the ignition pulse signal from the tach gate on the 90 coil to the ECU and Cluster.
I know for sure its not the original engine but they would have had to switch the harness too. The '90 noise filter is there and so are the other 90' parts, like the throttle body, external oil cooler, CAS, and Power Transistor.
So what I think is that the car itself is a 1991 and the harness and motor are a 1990. It's really weird but it makes sense even if it had a 1990 motor in it before because the car was made in August of 1990 even though its considered a 1991.
So I think if I put a 1990 gauge cluster in the tach will start working again but I'm not positive, that's why I came here to try and ask if you guys might know.
So what I think is that the car itself is a 1991 and the harness and motor are a 1990. Its really weird but it makes sense even if it had a 1990 motor in it before because the car was made in August of 1990 even though its considered a 1991.
It's an early 91, the factory switched over to 91's in June of 1990.
Check the ECU, if it's a 91 ECU it won't matter if you install a 90 cluster.
Will do, if it is a 1991 ECU how do I get my tach to work with the 1990 harness?
do you have a picture of where the noise filter attaches to the side of the intake manifold stay?
if you are standing in front of the car, facing the engine, what side of the intake manifold stay does the noise filter attach to?
My tach does fine at idle, but jumps and acts crazy when i start driving. I looked and the noise filter was screwed to the top of my intake. I now know it goes on the intake stay just not sure where.
thanks again.
See http://www.dsmtuners.com/forums/newbie-forum/37213-rpm-gauge.html#post325537.
Thereabouts. I've bolted mine directly to the intake manifold.
So i just found out where the noise filter went and low and behold there was already one on the bracket, so i plugged it in and the tach works, well sort of. At low speeds it works fine, with a fast acceleration it goes down instead of up and will then jump back to where it should be, so i went from a tach that only worked at idle, to now a tach that works at low gears but still jumps. Anyone else had jumping backwards tach issues?
    • eclipsemf
