Aem cam gears with 7 bolt cas!
Only the fidanza's are compatible with the 95 cas. You might be able to drill and tap holes for the trigger plate, but I would use this as an opportunity to upgrade to the 1g cas. It'll also let you adjust your base timing, which you need to do when you adjust the cam gears.
Do you even need adjustable cam gears. Are you actually going to use a degree wheel and dial them in or are you just buying them for looks?
Gotta be an easier way =/
There isn't.
The 1G cam sensor is slotted and allows base timing to be changed. All 2G's use a fixed cam angle sensor, even the 97-99 models which also read off the passenger's side of the engine. The fixed sensor means base timing cannot be altered....so with a fixed sensor if you advance the intake gear two degrees, guess what happens to your base timing?
Ok but that would mean I'd have to switch to the 6 bolt cas and Im not very good at Wireing and also wouldnt want to cut my harness. Gotta be an easier way =/
Say hello to the plug and play cas swap adapter available through RRE. Closest you're going to get to what you're requesting.
^ +1
That is an awful idea. Why not spend the money on something that will actually help your car such as a bigger fuel pump, maintenance, exhaust system, intake, new lower control arms, and so on. You should be running an upper timing cover any way so the cam gears shouldn't be visible.
I have the lower and mid timing cover as for everything else I just bought kelford 272's so I plan on adjusting the timing just not right now, don't know why that's a bad idea to plan ahead.
How do you plan on adjusting the cam gears? Are you going to buy a degree wheel and dial bore indicator? You don't really even need the adjustable gears for the kelford cams. You will also need something to tune with before installing the aftermarket cams, as well as aftermarket springs to support the cams. It sounds like you are trying to put the adjustable gears on your stock cams for now. There are FAR better upgrades before throwing a set of adjustable cam gears on stock cams. Not to mention the fact that you will have to buy a 1g cam angle sensor and a 1g cas harness. I consider extra work for no advantage to be a bad idea any day of the week.
Finley...., Just like Ed said, you need better springs, A beehive style, such as the Kiggley, Ferrea, or the GSC #5041.
DO NOT install Kelford 272 cams on stock springs, or manley singles, BC1100, or used EVO beehive springs. You will break parts if you do.
Also do not install the cams till you get link or some sort of tuning solution.
Leave the stock cams in till you have all of the supporting mods needed to install the cams and can tune them in.
You do know that the car is going to run bad with the aftermarket cams on the stock tune right? You are going about this the wrong way. You need to be able to tune the car before buying any aftermarket bolt on parts. You would of been way better off to spend what you did on the cam gears, cams and springs on ecmlink instead.
http://www.dsmtuners.com/forums/newbie-forum/341209-4g63t-valve-spring-info-2.html
Post #50 is your spring kit
Looks to be a straight single spring set up
Yes they will handle the lift of the Kelford 276/272 cams.
But due to the agressive ramps of the Kelfords, and the low seat pressure of the Manley springs #23125
You will hit valve float early in the RPM band.
Like I said before, You need to look at the Kiggley, Ferrea of the GSC #5041 kit.
The manley springs will work well with the HKS 272, BC272, Comp/FP2, and the Delta clones of them.
If you choose to still run this set up, please read theses threads about agressive cans and failed valve springs.
http://www.dsmtuners.com/forums/cylinder-head-short-block/377673-my-crower-valvesprings-failed.html\
http://www.dsmtuners.com/forums/cyl...0359-bc-spring-broke-half-destroyed-head.html
AEM cam gears will work with a 7 bolt cas. There are bolt holes in the back of them to allow it to bolt up. Kelford cams with manley singles and titanium retainers have seen 8k rpms for my talon over and over again with no loggable issues.
ok, was looking at this kit GSC #5041. better safe than sorry right? thanks for all your help!
Viper.... What pair of Kelford cams tho?
I would like to see how your springs test out now.
What is that for?
  • For sale 1g 90 Oil Cooler
    • kyler021
