Murci
- 38
- Apr 10, 2012
Las Vegas,
Nevada
Hello, thank you for visiting this thread.
I have purchased a head unit, 4 speakers, and an amp to replace the current stock setup. I currently have the door speakers replaced. In addition, I hooked up the head unit to test the speakers. The right door speaker works great! However, the left door speaker is not working. I used a voltimeter to test the circuit. I believe there is a short.
1) But before I approach this problem, is there something I need to know about the left side? More specifically, is there anything restricting the connecting between the head unit and speaker that I don't know about? I'm not sure if the speaker also need to run through the amp as well to function properly. WTF
2a) Another question I have encountered: do I just cut the wiring harness that used to connect to the stock amp and wire it to the new one?
2b) If I do need to cut the wiring harness, does anyone have a wiring diagram for the amp? If so, please post it and link it.
-Jordan
I thank everyone in advance who can provide input to my questions.
-Jordan
