dsm-junkie
- 277
- 1
- Jan 20, 2012
miami,
Florida
hey guys
Yes you need the vacuum line. It should be coming off the nipple on the intake manifold.
Nice build doing my tsi right now, youll like the innovative wideband set up.
Glad to see you strayed away from hondas
Yeah! Only way to crack 300 whp is to drop serious $$$ Couldn't do it anymore!!So are you trying to get your money back from the built block?
Nice you don't give up.
If you would off posted before you send your block to the machine shop, I would off give you my short block for very cheap, so you can save some money on the machine shop, It is STD, hone, deck, new frees plugs, new stock pistons and rods.
I rebuild it but got the wrong bearings and it start knocking on my first spool when tuning, the crank is junk and I think the rods as well, But the rest is new.
I found a G4cs which I am building, so no longer need the 4g63.
However, Good luck on the build, check everything twice and do your self a favor, don't cut turns.
