Wire tuck & fuse box relocation
alright let us know take pics, I'm actually really interested in doing this now figured shave bay turbo would look dandy
So my above after today is... Leave against fire wall on floor.... Tuck all wires into center council and under dash....
Looks good!
I'm in the process of doing something similar..
2G DSM
Check out all the pics, Love people who spend some time on the wiring. Love it!
Make sure run O2 and coolant temp sensor through passenger fender. Route headlights through bumper...I took plastic dam out cause I'm porting holes through bumper air flow + (similar to honda bumper holes...reverse concept though)
Well i got the harness out and most deloomed, started to feed through the fire wall to rout them and i got some but it begun to get messy and tangled. I would love pics of the places you routed the tranny, tb, coil pack sensors and a pic of how its tieyed up coming out of the fire wall
Is there any other way I can reach you instead of on here because im running into some big problems with the tuck and i need help asap.
need to know if you deloomed the whole harness.
did you tape all the sensors/wires individually
(mine is getting tangled up casing some not to be right)
how did you route them to make them "tucked"
Do I need to relocate the fuse box to make my life eaiser when doing this? just the little things i am caught up on thats making me mad.
Yes, single out each sensor, or " inline" group, twist and tape. Then once that done then route them.
Map, iat should be together.
Knock, alt, crank together
So on so forth
https://www.youtube.com/watch?v=u1Z2NbiAXnw&feature=youtube_gdata_player
Lifter tick:what:
Still tidying up and getting passenger seat. But figured show you what had done....
