Anyone know of an adapter for 1G caliper thread male to 2G (3/8") banjo?
TrevorS
515
4
Feb 10, 2009
Newark, Delaware
As the title says, I'm looking for an adapter that accepts a 1G sized brake caliper hose thread (male) and ends in a 2G sized banjo (3/8" I believe). Looked around some and haven't spotted one yet. Any suggestions?
I've learned the threads are actually 10mmx1.00 and I picked up a pair of female unions at the local NAPA store. However, I'm having trouble finding a 10mmx1.00 male banjo adapter, I suppose the angle should be 30 to 35 degrees. It's easy to find bolts, but it's the banjo itself I need. Anyone know of anything?
RRE used to make brake lines for a 1G that ended in 2G banjo fitting for peoplw who used 2G calipers doing the Big Brake upgrade. They are still listed on their site. RRE's Eclipse Brake Upgrades under Adapter Brake Lines
Yep, I communicated with Mike and turns out I can get a pair of those outer lines for $48 shipped, but that's a bigger bite than I can handle just now. Tried looking into 10mmx1.00 male or female to 03-AN female adapters since that would also work, but not having much luck spotting 03-AN females :(!
Thanks, but unless I'm overlooking something (always possible :() that page provides a collection of banjo bolts, my problem is the line connection to the bango. My line is 10mmx1.0 male and I can handle either male or female, but I need to be able to connect to a banjo, and I've yet to figure out how to do that. Connection of the banjo to the 10mmx1.0 caliper inlet should be OK (either 10mm or 3/8" will do LOL!
    • eclipsemf
