BBRTuning Time Attack/NASA TT 99 GSX
eclipsegsx1736
Supporting VIP
1,599
44
Nov 11, 2003
Los Angeles, California
Ok, you guys win, I've finally started a build thread! When I bought this car (Binkie is her name.. don't ask :) ) back in 2004, I knew I would modify it, but I would have NEVER dreamed that the car would come as far as it has now. The car was my daily driver for years, even when it was around the 450-500whp range. I drove it in that trim every day. Sure, some stuff broke - but overall, producing well over double the factory HP, the car was damn reliable. After a few years of working on these cars, you sort of learn what it takes to keep them held together. It just takes a few of the right parts, and a few tricks here and there that you learn along the way.
About a year ago, I picked up another fun and reliable GSX as a daily driver, and I finally made the big never-turn-back decision to take Binkie off the road for good and prepare her for Time Attack competition, specifically the 2012 Global Time Attack Street AWD class. Why the "street" class? .. Have you seen the cars in Limited (the next level up)? "Street" class cars in TA these days are full race cars. You need 500hp to even stand a chance. Full cages, aerodynamics, the whole lot, all pushed to the limit of the rules. Limited cars are in the 600-700hp range, and add DOT R-compound race tires to the mix, which results in some HUGE costs to allow the car to handle those G-loads. You're talking at a minimum AccuSump systems, and ideally dry-sump conversions for such high G's. This is why I chose the street class - at least initially. Who wants to compete in a class that you just have NO chance of competing when you're on track with full sponsor-backed shop race cars?
As I've quickly been realising, preparing a car (and myself) for Time Attack is an ENORMOUS undertaking. The GTA rules are specific and strict, and GTA in particular runs under NASA CCR rules, which again are very particular, especially on safety. The tech inspections are nothing like a drag strip - they really look at everything, even using ultrasound-type devices to check wall thickness of roll cages. Another big hurdle - you have to be at least NASA HPDE-4 approved, and ideally have a NASA TT (Time Trials) certification. This means at least attending several NASA track days driving in HPDE, working your way up through the classes, each time getting signed off by an instructor, by demonstrating proper driving, safety, passing and racing lines, etc. And we haven't even discussed building a car that's fast enough to even compete.
It's also expensive. The entry fee alone is $500. Road racing in general is expensive. Expect to wear a set of tires out in maybe 3-4 weekends, and, depending on your brake setup and your driving, expect to replace your pads (race pads too - $500+ for a car-set or so) every other event, or worse.
But, there's nothing like it. I used to drag race. It's a joke compared to road racing. You want horsepower and straight line speed? That's what the straightaway is for. Who wants to play car bowling? Ever watched an F1 or an ALMS race? Circuit racing will take over your life and you'll roll your eyes at drag racers. It's not elitist.. it's just that much more fun. :)
If you want to catch up on the custom radiator ducting system I built, as well as see a some video/pics from me driving in NASA HPDE in my daily driver, attempting to make my way up through the HPDE system, here's the link to that thread:
http://www.dsmtuners.com/forums/custom-fabrication/386716-my-ducted-radiator-setup-road-racing.html
Finally, a picture of Binkie hitching a ride on the U-Haul Express on her way to have the cage built!:
Anyway, onto the build!
The first GTA event at Buttonwillow is on April 21/22nd. The weekend before that, April 14/15th, is a track day at Buttonwillow. I know I'm cutting it close, but in order to get everything done in time, I've set that weekend as my one (and only) shakedown/test of the car with the new setup. Not only will it be a HELL of a time getting the car ready for that test day, but only having one weekend to shake down the whole car and dial in the suspension alignments, brake balance, aero balance, etc. It's going to be nuts. Anyone who wants to come watch or support/pit crew is more than welcome :thumb:
The car is currently at [removed] getting a full cage done, mounting my new Sparco Evo and 6-point belts, mounting the APR GTC-300 rear wing to the chassis, aluminum sunroof insert, as well as installing Kevin's (greengoblin on here) badass fender braces. I will of course be updating the thread with pics of this work as soon as I can!
Immediately after the cage is installed, I'll be taking the car to have the entire suspension overhauled. This includes:
-install Adam Porto's F/R subframe + rear diff bushings
-replace all suspension arms, wheel bearings, tie rods, links etc with new OEM units
-Prothane full bushing kit
-spherical bearings in front lateral arms
-corner balance/full race alignment
From there, I'll be tuning the car on the AEM EMS on the dyno, myself of course :D . And, finding time for the rest of the misc work to do (I'll be using this list as a checklist for myself as well :) )
-install AQ-1 datalogger system, GPS unit, all engine sensors etc
-install fire extinguisher
-JMF oil & coolant catch cans
-Fluidampr crank pulley
-finish building dash panel/gauges/warning light system etc
-loom up any remaining un-sheathed wiring in cockpit
-rear tow hook
-build IC/rad duct for front bumper to feed exit duct
-front splitter + dive planes + mounted to chassis
-Evo 8/9 rear diff if anyone has one, please let me know!!
Here are some pics of random goodies that just came in for Binkie:
Sparco EVO FIA seat + Sparco FIA 6-point HANS harness:
Federal 595 RSR in 255/40-17. These are the next best thing to Hankook RS3 for the price, which are the best tire right now for "street" class, which mandates a tire treadwear rating of 140 or higher.
Obligatory parts-build picture.
A few weeks ago, I did a NASA track day at California Speedway in Fontana, CA in HPDE-3 just for the track time and the experience I drove my daily-driver 98 GSX in this event since Binkie wasn't quite ready. It was cool to drive on this track, being that it's host to one of the big NASCAR races. I don't watch NASCAR, but the idea of racing on the same oval (or at least, we use half the oval and the inboard road course, usually called a "roval" layout) as NASCARs and the same track that millions of fans watch every year was pretty neat to think about.
The car has Megan coilovers, RM ARBs, GT30R (turned down to 12/13 psi for this event to keep the engine cool), stock engine, etc. I also mounted a set of Continental race slicks that were take-offs from a Grand Am race car that I had on Binkie before - wow these tires are pretty crazy :D Pulling avg 1.1-1.2G through the unbanked turns. This is with almost no front camber, and these tires need 2.5-3.5 degrees typically. As you can see from the pics, I stole the hood off the white car just to get some extra venting for the radiator. Obviously, there's no accompanying radiator duct on this car but a hole is better than nothing, eh?
Video is from a Go Pro. All data is collected from an AEM AQ-1 Datalogger, an invaluable tool for any racer. You'll learn SO much about your driving and your car for only a few hundred bucks.. For instance, I was a bit scared to push the car harder around the oval bank. It was my first time on that track and the first time in that car on a track with 100+ mph turns. From looking at the data, I was leaving a LOT on the table through that turn. I could have easily gone 10 mph faster and still been under the limit of the car. At that speed, though, it's much harder to tell where the limit is.
Speed data is collected from a Garmin 5hz GPS in case anyone's curious. The AQ-1 has it's own built-in 3-axis accelerometer. AEMData data analysis was used to collect the data and create the track map. The rest of the data is tapped from the ECU (DSMLink on this car).
Video link (watch in HD!):
Eclipse GSX at Cal Speedway roval NASA HPD3 Sunday 4 March 2012 - YouTube
Finally!! I was waiting for this since i PM you. I just wana say thank you for making DSM known for something else than drag racing.
Glad to see you finally gave in, Beau! :hellyeah:
Looks like a pretty nice plan you have laid out. A couple questions for you.
1. Do you plan on mounting the wing directly to the rear deck, or more securely to the frame rails?
2. Any reason you're going with a vented catch can over a sealed catch can?
3. Do you plan on having the inboard pickups on the front crossmember raised (Robi mod)?
4. Are we going to get more pictures of the duct setup? :D
It's great to see you doing a build thread. I look forward to watching your progress!:D
Keep it coming! Love using Kevin's and your car as inspiration.
Thanks Kevin(s)! Well, the feeling of inspiration is mutual!
Thanks for the support! Although, luckily there are a lot of other DSMers to thank for this now than there used to be.
1. The wing supports/uprights will be solidly mounted to the chassis, meaning that nothing will actually be touching the trunk. The trunk metal is pretty weak on these cars, so even making a support for the trunk isn't enough IMO. While downforce will of course push downward on the trunk, the drag created by the wing will work to pry the wing and trunk backwards, which is very hard to brace without mounting direct to the chassis, especially for the high wing angles typically used in Time Attack cars due to their higher horsepower..
2. Good question..The vented catch can is for several reasons. I change the oil after every event, so I'm certainly not worried about fuel vapor contamination (side note: even when I daily-drove the car with a vented can, after 3000+ miles of hard driving on E85, I've sent oil samples in for analysis and they've come back perfect with no contamination). Also, since I’m in boost the majority of the lap (typically avg. throttle position of 60-70% for the whole lap at most tracks), a PCV-based system would be almost useless, as it only vents vapors with manifold vacuum. I’ve thought about other methods of proactively venting crankcase pressure and vapors using the intake pipe vacuum, etc, but a simple vented can is much easier to deal with and works perfectly for now. I haven’t had any crankcase pressure issues even at close to 30 psi.
3. I am planning on doing that mod, although at the price for the mod I’m going to hold off on it a bit until I feel how the car is with the new setup. Also, the rules in “street” class on that subject are somewhat of a grey area. Exerpt from rules: “On strut type suspensions the outer end of the lower control arm may be adjusted a maximum of 1-inch. On vehicles where the above is not possible by OEM design the inner pick up point may be adjusted a maximum of 1-inch.”. We don’t have “strut” type suspensions, hence the grey area..
4. Yes! Certainly. Once I get the ducting for the front bumper inlet finished, I’ll post more pics for sure! I’d love to do a yarn-tuft demonstration on the flow patterns around the duct too but this is tough with a car that’s not street legal.
Beau
Wow, what a tremendus build, wish I had seen all of that before, specially from someone with experiance on these cars.
There are a lot of similarities between your car and experiances about road racing, as I tell a lot of my DG friends, once you get into a RR you will never look back.
If you can, take a look at my build under RR, I am starting with what I know and giving me more time about the rest of the car, your opinion will be most welcome.
May suggest something I noticed in your video and you may have to change your steering wheel for that, but try to keep your left thumb around the wheel like you are doing with your right, many things can happen and that wheel is going to go where it wants to.
Anxious to see more.
arrowhead
This I knew, so it's good I'm thinking on the right path. Just wondering seeing as John (black 2g with Drew's kit) mounted his to the trunk, so I'll be curious to see how the two compare. Nothing against John or the shop, but I hope that doesn't cause any major issues once he gets it out on the track.
I'm very interested to see how you accomplish this. I'm guessing you'll just notch the hatch around the edge to allow a brace to pass through and then bolt to the frame rail?
eclipsegsx1736 said:
3. I am planning on doing that mod, although at the price for the mod I'm going to hold off on it a bit until I feel how the car is with the new setup. Also, the rules in "street" class on that subject are somewhat of a grey area. Exerpt from rules: "On strut type suspensions the outer end of the lower control arm may be adjusted a maximum of 1-inch. On vehicles where the above is not possible by OEM design the inner pick up point may be adjusted a maximum of 1-inch.". We don't have "strut" type suspensions, hence the grey area..
Exactly why I was asking ;) I want to know where the line for the grey area is. Drew has the mod done though, so is it still really a grey area, or is he running in a different group (non-GTA)/under different rule set? Last I knew he was doing RTA which I think still used the CCR as a base rule set.
arrowhead
Thanks! I’ll definitely check out your thread.
Yeah, I know what you mean on the steering wheel grip. Annoyingly, the Momo hub I has the steering wheel not quite straight (about 5* off from straight or so), so subconsciously I find myself having an uneven hand grip on the wheel so my hands are level with each other. I took this wheel/hub off my white car, which on that I had the car aligned to compensate for the slightly offset hub.
Yeah, the hatch will have notches cut out so the supports go through the trunk. It’ll mean I’ll have to remove the wing element to open the trunk, but there’s not thing really back there so I shouldn’t need access much. If I do, though, it’s 4 bolts so it’s quick.
I believe Drew last ran in what is now called the “Limited” class which allows those types changes. Last I heard, he’s planning on being at the same Buttonwillow GTA event as me in the Limited class. Very exciting stuff if that’s true!
PS - I edited the post with the Cal Speedway in-car video and added some pics I forgot to include!
Sorry to be the bearer of bad news to anyone, but if you mount any wings to any car on the trunk unless you do some pretty hefty reinf. to back it up, once you really start cooking, it will be bent, torn or worse.
That should fall under safety rules somewhere.
I have seen them fly and it is not pretty.
I have been thinking/ dreaming about wing mounts for some time. I left year sketched a few designs n decided I really wanted to have them come down behind thr deck lid and tie into s bumper like support. this would give the wing a better mechanical advantage and also feed the loads directly into the chassis. I just recently saw a picture of the greddy gtr and really like how they have it done.
Nissan GT-R : Since 2007: Ben Sopra GT-R
That would work.
I've always liked that method as well, although there's one thing that I'm curious about. I'm not sure the mechanical advantage is really an "advantage" in this case, especially on our cars. It would seem to me that applying a downward force aft of the rear "axle" would tend to lift of the front of the car, essentially reducing front downforce which is exactly what we don't want on our front-heavy and cars with driven front wheels. Try pushing down on the trunk of a model car; the front will lift off the ground. If you push down directly on the axle or rear shock tower area, this doesn't happen. Thoughts?
I suppose this is the thinking behind World Racing's FWING Scion. The front wing plane is so far out front it has the same effect but on the front end, which of course is needed on a 1000+ HP FWD car!
I do not think this would be an issue for me with the aero work i have on the front of my car. Last time I talked to Drew he need more down in the rear. I suppose it "might" be an issue on a more stock car but " think" with good aero work done to the front it would not matter. This would be a good question for Drew.
Not worth posting, unfortunately :toobad: I've had various issues with shops doing some work on the car but I should have an update any day now and will post as soon as I do. The current plan is to have the car ready and tuned for MOD 2012 (Mitsu Owner's Day), then schedule in a few Buttonwillow test days before the next GTA event also at Buttonwillow in November!
It's mainly centred on one shop, which I've already told you some about. I'm not going to post specifics on here with the intention to not bash any shops. :) The important part, the quality of the work, is good, it's just how much longer it's been taking than originally promised.
Finally! A wild update appears! What a process this has been. I had a lot issues with the fab shop I first brought the car to. The work was good, but grossly behind schedule. It caused me to miss the first event I had planned for the car, and set me back a few months of build time/testing. However, the work was good, and in the end it came out nicely, so I've removed the name of the shop to avoid bashing.
I ended up pulling the car out of there with the work about 2/3 done and took it to another local shop. I had a much better experience there, the work got done quickly and I was happy with the work!
Mitsubishi Owner's Day is this Saturday (14 July), and I have only one day (tomorrow!) to get the car "ready". I say "ready" because I planned on having the car soo much further along than it currently is, but at this point the objective is to bring the car out there and throw it on the dyno (Mitsubishi sponsors Road Race Engineering to bring their AWD Dynapak dyno to the show to spice up things a bit).
It's not yet fully tuned on the EMS, so tomorrow Binkie heads to FSR Motorsports Creations in Montclair, CA for some tuning! The guys at FSR are going way out of their way to give me free dyno time on their AWD Dynojet dyno! I'll try to have some video of me tuning her for you all to see, I'm hoping for about 500whp and close to 500wtq, which should be attainable at about 27-29 psi on E85. Beyond that boost level, the .63 hotside becomes way too restrictive. Unfortunately, I won't have time to swap in my set of FP3 cams, so I'll still be on the FP2s which will be holding me back a bit up top at the power levels I'm going for. Wish me luck!
Below are a few pictures of where the car's at now. I still need to paint the cage and clean up the interior. Next on the list of big things is to replace basically all the components in the suspension (Robispec front roll centre mod as well), install the Evo rear diff, get the car aligned, and finish the front bumper air ducting as well as build the front splitter and dive planes.. The car is filthy inside and out right now, but I'll certainly post up much better pictures once I clean the car out and paint the interior!
Beau
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
