freakingbori617
- 47
- Apr 8, 2008
BOSTON,
Massachusetts
ok guys so i did my first alarm install. Time consuming but i wired everything up. The alarm works perfect. No problems but the remote start shows error. I wired the neutral safety wire to the ebrake. But there is H1/1 WHITE/BLUE (-) REMOTE START/ TURBO TIMER ACTIVATION INPUT H1/1 that i donot know where it goes to. I heard it doesnt need to be connected not sure though. please help guys
BElow is how I wired the remote start harness from the alarm to my ignition harness.
(H3) 10-pin connector
H3/1 PINK (+) IGNITION 1 INPUT/OUTPUT =Black/White ignition harness
H3/2 RED/WHITE (+) FUSED (30A) IGNITION 2 / FLEX RELAY INPUT 87 = White ignition harness
H3/3 ORANGE (+) ACCESSORY OUTPUT = Blue
H3/4 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL) = Black/Red Ignition Switch Harness
H3/5 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL WIRE) = Black/Red Ignition Switch Harness
H3/6 RED (+) FUSED (30A) IGNITION 1 INPUT = White ignition harness
H3/7 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT = Blue/Black ignition harness
H3/8 PINK/BLACK (+) FLEX RELAY INPUT 87A key side (if required) of FLEX
RELAY = Cut short and tape off
H3/9 RED/BLACK (+) FUSED (30A) ACCESSORY/STARTER INPUT = White ignition harness
