Quote:
Originally Posted by donniekak
As long as you run e-85 it should be fine. I've run some aftermarket 9:1 pistons on e-85. The timing didn't quite match the agressive stock map, but the boost was also higher, so you should be ok. Being up north, you are going to find out how e-85 acts when it's cold out. Hard starts, and your heater won't work for 10 minutes. Oh yes i'm on 3si also.
I don't care where in Arizona you are, it ain't cold there.
