forcefed86
- 1,007
- 14
- May 23, 2006
wichita,
Kansas
So after spending a couple more hours with the car today I'm stumped.
Car idled and ran great before I installed 750cc injectors and a 2g maf. No other changes.
Car now runs, No CEL. (14.5afr's at idle) Car now has an idle surge. Is this normal when still running factory ECU/eprom? I'm waiting on my chip at the moment. Just thought I'd get a head start on it.
I've checked all my vac lines several times, everything is as it should be. All the lines on the turbo intake pipe and top throttle body are capped.
The barb on the intake manifold closest to the TB is routed down to a "T" one going to the BOV, the other going to the MBC. The other barb on the intake closest to the FPR also has a "T" one side going to the boost gauge, the other to the AFPR.
The barb on the turbo outlet charge pipe is going to the alcohol injection boost switch.
Are there any other lines I could be missing?
I've checked the TPS and IAC etc. All pass resistance and voltage checks.
Any ideas?
Thanks
Any ideas?
Thanks
, I told you not to install those until you got your tuning stuff.
