hpexperts
- 193
- Sep 30, 2007
Franklin lakes,
New Jersey
Just finish putting in my new motor in my 1G, 6 bolt. last night i tried starting it to break it in and it blows or loosens my oil filter when first starting in last than 5 seconds of running.
I removed the balance shafts, i still have oil squirter's and i didn't port the OFH, my oil cooler line is a lil kinked, and i am using 10/30 oil to break the motor in. i don't know what the oil pressure reading is but i think its excessive. after doing some research here lots of people are porting the OFH does anyone have a pic of the before and after port job? is there anything i can do the spring and piston to lower oil pressure? will removing or installing a larger oil cooler with bigger lines lower my oil pressure? did anyone have this problem b4? what else can i do? i don't want to take the motor apart.
