PandaMan
- 187
- Mar 7, 2009
Newberg,
Oregon
So my car went down last month with an electrical issue blowing ignition fuses. I finally found that pesky wire that was grounding out yesterday. While the car was down I replaced the fuel filter, rear o2 sensor and the coolant temp sensor. Now the car cranks over just fine and all but the car won't start
I've pulled the injectors to make sure they are clean (heard e85 can clog them) and my fpr reads 40 psi and everything seems to be snug and connected.
Thoughts?
I run on e85 if that makes a difference.
I've pulled the injectors to make sure they are clean (heard e85 can clog them) and my fpr reads 40 psi and everything seems to be snug and connected.Thoughts?
