the_mork
- 2,619
- 26
- Mar 10, 2008
Eau Claire,
Wisconsin
If anyone has a GM 3 Bar MAP and IAT sensor or a few bucks they could donate, so I could do some testing. It would help get things moving along. Thanks.
If someone had a spare H8 computer and 2.0 cable I could borrow then I could try it.
Check out ebay for the MAP sensor and I'll try to figure out where I bought the temp sensor for my setup. My MAP sensor was about $45 and my pigtail and temp sensor were about $30. Welding in a bung was much more expensive and a bad experience for me. The idiots down at the exhaust shop told me they could weld aluminum then didn't get it done because the people they were subbing out to didn't get to it. I guess knowing someone that welds is the same as welding these days... Then they charged me $100 for it AND didn't seal my TB to the elbow worth a damn so I had to do it over again. They also welded it in upside down after I told them which way was up. Long story short do your homework on your welder. By the way get a bunch from Summit, it will be cheap and I can almost guarantee that in a medium city no one will have one on hand.
.. but Thank you keep us posted on more INFO!!
