Quote:
Originally Posted by Burnett03
That's exactly what i said.. A 50trim doesn't flow much more than an evo3 16g. A 50trim has been shown to flow MAX around 50lbs a min. Most people never get that high, most get around 46lbs a min. I've seen evo3 16g's flow 44-45lbs a min easy.
RYAN! Where are all these accurate 50lb/min logs of evo3 16g builds
Ryan, I've been on the link forums as much or more than you and that 46lb/min number simply is not the case. I swear! A few accomplished builders push a turbo to 499whp and all of a sudden you have everyone blasting that it can flow 50lb/min. . . Who cares what the accomplished show for airflow. . .
The evo3 16g flows 42lb/min based on the map and the 50-trim flows 49lb/min based on the map. Whoever can make 500whp with the evo3 16g can make 550+ whp with the 50-trim. No one who's made that number with the evo3 16g has gone to a 50-trim. <==That's the secret. . .
