Devils own progressive kit & a dual image eprom chip
ebanks89
56
May 1, 2005
New Castle, Delaware
I'm getting the devils own progressive kit tomorrow and was wondering since I have a dual image chip would I be able to switch over to my race map in my ecu once I get the kit running? street map has 18 degrees of timing up top and a 11.1 afr @ 22psi with no knock, while my race map is for unleaded vp racing 109 octane with 24 degrees of timing up top and a 12.1 afr with 26-30 psi, so can this work using meth injection and 93 octane?:hmm:
Its possable, remember the meth is going to shif your lambda. I recomend taking baby steps while tunning. Might want to start off with 24d-26psi and see how it reacts first befor jumping to 30psi. With all the extra timing you are running.
  • For sale 1g 90 Oil Cooler
    • kyler021
