View Single Post
Old 07-04-2009, 06:39 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
rush2252 Offline
Proven Member
rush2252's Avatar
Tech Posts: 1,113
Classifieds Rating: 3
Reputation: rush2252 is more helpful than not
remember your going to have deflection between the cam gears before you start the motor. If done correctly you should be able to line the CAM gears up, then set the crank to TDC and work the slackaround to the tensioner side. Ive never done the modification to swap tensioners but I ran into a similar problem on my 99GS. Your probably not accounting for the deflection allowed to have the belt properly tensioned.
____________________________
Kolby
95 GSX
View this member's Blog
