talon187
- 1,043
- Feb 11, 2003
torrington,
Connecticut
ok I was going up the road all fine and dandy. all the sudden i went to give it gas it boged saw 10.0 on a/f so i let off figured i need to take away fuel with the new setup. I look over at the rpm gauge its at 0 i got it up the road maybe a half mile pulled over. shut it off. started it again still same thing. Also the fuse for my blower motor poped. I let it still for alittle started it the rpms would go up to 1200 fall falt on its face. id give it gas for a second and then it would fall falt on its face again i let it still for a few more mins and it started normal i got it across the street and up the hill to a family members house and left it there. Im wondering how do you tell if a map sensor is bad? I dissconnected mine and the car idled perfect but went lean so i shut it off. Also the car has a fresh motor and head with a sbr 30r dual ball bearing turbo. im running 780 injectors with a stage 3 chip from jeff at dsm chips and im using a maf pro to tune with converted to speed density please help!
