Are you using MS to control fuel and spark?
If you're controling ignition with MS then you can basically do whatever you want.
If you're just using MS to control fuel, then yes, I would say 14psi is about the maximum, if you're using the standard Star Turbo, or equivelant, that is. Around that you'll start to run into some problems with detonation, due to the stock ignition advanced timing.
____________________________
Ryan
