- 10,748
- 59
- Jun 13, 2002
Chapel Hill,
North Carolina
Alright, as some of y'all know, I've been battling pesky knock between 5.5k and 6k. Last week, I took the car to a friend's and BLT'd to 25lbs. The WG arm was loose so that was adjusted tighter...no more hearing me bi*** about slow spool. We also adjusted the slave cyl since it was dragging and that was about it.
Here's a clipped log showing a quick pull onto the interstate and the full drive to Bojangles before work log. Boost set at 15-16psi.
. I checked there so as not to be thought a fool. Still can't find it, but not too worried.
. Especially since this turbo is not a "hot-air pump" at this point, not even close. The timing only seems to drop 1* from 12-11 at 53-5400rpm. and comes back up 12* by 6k. He was about 11.4:1 at 5300rpm, so maybe try setting the timing back to 11* degrees here or see what adding fuel does?
