well you got a few things here it could be , you could have a boost leak somewhere else aside of the BOV ... however are you venting to the atmos? or do you recirculate. if you vent try recircing and see if that fixs it if not i'd look into the bov to see if the gasket is leaking or something of that nature .chekc you IC piping too make sure you dont have coupler ripped or anything my buddy blew hsi reducer and had boost but it didnt pull likei t boosted even though the gauge said he was pushin 16 psi. so just make sure to check all lines for boost leaks check your ic piping and couplers and make sure your bov isnt leaking
