If you can't get the connection to sync', then shut down HotSync Manager and restart it. It'll detect the cable and should sync' now.
To shut down the sync feature click on the hotsync icon in your toolbar. Go to the Palm program in your "All Programs" on the start menu and click HotSync Manager to restart.
Also make sure you have the appropriate type of cable "check marked" in the Hotsync Manager. I couldn't figure mine out for a while as I connect using a USB adapter to the serial plug on the cradle and I had the same problem.
