slowgsr
- 862
- 10
- Dec 17, 2007
hamilton,
ON, Canada
Well, last weekend I went 11.7 @ 123mph on the stock block with 180 xxx KM on it. This was on pump 94 and a mix of 75/25 meth/water.
60ft - 1.8391
330ft - 5.0741
1/8et - 7.6661
1/8mph - 96.38
1/4et - 11.7040
1/4mph - 123.01
I can probably do a sub 11.5 once i get the car to leave better, so im pretty happy. This was on 24lbs on a S258 0.70a/r. The rest of the setup is in the profile.
I need to do some more tuning, im still running very little timing and use straight meth instead of a mixing it.
I was leaving at 5000rpm with about 12lbs of boost, slipping the clutch. Lots of potential with these stock motors. Using AEM to tune. The car has no AC/PS/Heater I had the passenger and rear seats out. Otherwise, all full weight.. just a CF hood.
How does my slip look? Where should I try and make some improvements? I think its got a few more tenths left in it at this power level.. If not i will just turn up the boost once i run the straight meth, its great stuff.
Thanks.
60ft - 1.8391
330ft - 5.0741
1/8et - 7.6661
1/8mph - 96.38
1/4et - 11.7040
1/4mph - 123.01
Thanks.
man i should have looked at it closely... i just thought i saw 180xxxk not km
