Please Support Kiggly Racing
Crap chrysler tranny wont shift out of first HELP PLEASE!!!!!!!!!!
rarest_90_DsM
285
3
Jul 21, 2004
akron, Ohio
My daily is a 99 eclipse rs with a automatic tranny had a fluid leak got it fixed (cooler line) drove the car about a month then it started not shifting one day and hard to select the gears i checked the tranny fluid was low filled it up drove about a week it was fine. Got in it today fire it up go down the street and it wont shift out of first WTH checked the tranny fluid its full idk whats goin on i need help i work on first gens not use to this Chrysler stuff HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! COULD THIS BE LIMP MODE???:banghead:
All automatics function similarly, Mitsu or Chrysler.
Check for codes, (P0700 from the ECU) and find out where the fluid leak is. A bad front pump can cause you to not shift gears, and leaking from the input shaft seal often accompanies a bad pump. Many things can cause the transmission not to shift, such as a faulty TCU, bad shift solenoid or wiring, stuck valve, and worn clutch packs.
Limp mode will result in your being stuck in second. If you're stuck in limp mode, clear the codes to get out of it.
Chrysler tranny chrysler motor chrysler code so i found a list since we dont have one:hellyeah: so the P1768 code means
P1768 Relay Output Always Off what does this mean??????????????:banghead:
COMMUNICATION
P0600 PCM Failure SPI Communications
P0601 PCM Internal Controller Failure
P1685 Wrong or Invalid Key Message Received From Skim
P1686 No Skim Bus Message Received
P1687 No Cluster Bus Message
P1693 DTC Detected In Companion Module
P1695 No CCD/J1850 Message From Body Control Module
P1696 PCM Failure Eeprom Write Denied
P1697 PCM Failure SRI Mile Not Stored
P1698 No Bus Message From TCM
CHARGING
P0516 Battery Temperature Sensor Low
P0517 Battery Temperature Sensor High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0622 Generator Field Not Switching Properly
P1492 Battery Temperature Sensor Voltage Too High
P1493 Battery Temperature Sensor Voltage Too Low
P1594 Charging System Voltage Too High
P1682 Charging System Voltage Too Low
P2503 Charging System Voltage Low
DRIVABILITY (Gas Engine)
P0016 Crankshaft/Camshaft Timing Misalignment
P0031 O2 Sensor 1/1 Heater Circuit Low
P0032 O2 Sensor 1/1 Heater Circuit High
P0037 O2 Sensor 1/2 Heater Circuit Low
P0038 O2 Sensor 1/2 Heater Circuit High
P0051 O2 Sensor 2/1 Heater Circuit Low
P0052 O2 Sensor 2/1 Heater Circuit High
P0057 O2 Sensor 2/2 Heater Circuit Low
P0058 O2 Sensor 2/2 Heater Circuit High
P0068 MAP Sensor/TP Sensor Correlation Vacuum Leak Detected
P0071 Ambient/Battery Temp Sensor Performance
P0072 Ambient Temperature Sensor Circuit Low
P0073 Ambient Temperature Sensor Circuit High
P0106 Barometric Pressure OUT of RANGE
P0107 MAP Sensor Voltage Too Low
P0108 MAP Sensor Voltage Too High
P0111 Intake Air Temp Sensor Performance
P0112 Intake Air Temp Sensor Voltage Too Low
P0113 Intake Air Temp Sensor Voltage Too High
P0116 Engine Coolant Temperature Circuit Performance
P0117 Engine Coolant Temp Sensor Voltage Too Low
P0118 Engine Coolant Temp Sensor Voltage Too High
P0121 TP Sensor Voltage Does Not Agree with MAP
P0122 Throttle Position Sensor #1 Voltage Low
P0123 Throttle Position Sensor #1 Voltage High
P0125 Closed Loop Temp Not Reached
P0128 Thermostat Rationality
P0129 Barometric Pressure Out of Range
P0131 O2 Sensor 1/1 Circuit Voltage Low
P0132 O2 Sensor 1/1 Circuit Voltage High
P0133 O2 Sensor 1/1 Slow Response
P0134 O2 Sensor 1/1 Stays at Center
P0135 O2 Sensor 1/1 Heater Failure
P0136 O2 Sensor 1/2 Heater Circuit Malfunction
P0137 O2 Sensor 1/2 Circuit Voltage Low
P0138 O2 Sensor 1/2 Circuit Voltage High
P0139 O2 Sensor 1/2 Slow Response
P0140 O2 Sensor 1/2 Stays at Center
P0141 O2 Sensor 1/2 Heater Failure
P0151 2/1 O2 Sensor Shorted to Ground
P0152 2/1 O2 Sensor Shorted to Voltage
P0153 2/1 O2 Sensor Slow Response
P0154 2/1 02 Sensor Stays at Center
P0155 2/1 O2 Sensor Heater Failure
P0157 2/2 O2 Sensor Shorted to Ground
P0158 2/2 O2 Sensor Shorted to Voltage
P0159 2/2 O2 Sensor Slow Response
P0160 2/2 O2 Sensor Stays at Center
P0161 2/2 O2 Sensor Heater Failure
P0171 1/1 Fuel System Lean
P0172 1/1 Fuel System Rich
P0174 2/1 Fuel System Lean
P0175 2/1 Fuel System Rich
P0182 Fuel Temperature Sensor Voltage Too Low
P0183 Fuel Temperature Sensor Voltage Too High
P0201 Injector #1 Control Circuit
P0202 Injector #2 Control Circuit
P0203 Injector #3 Control Circuit
P0204 Injector #4 Control Circuit
P0205 Injector #5 Control Circuit
P0206 Injector #6 Control Circuit
P0207 Injector #7 Control Circuit
P0208 Injector #8 Control Circuit
P0209 Injector #9 Control Circuit
P0210 Injector #10 Control Circuit
P0221 Throttle Position Sensor #2 Performance
P0300 Multiple Cylinder Misfire
P0301 Cylinder #1 Misfire
P0302 Cylinder #2 Misfire
P0303 Cylinder #3 Misfire
P0304 Cylinder #4 Misfire
P0305 Cylinder #5 Misfire
P0306 Cylinder #6 Misfire
P0307 Cylinder #7 Misfire
P0308 Cylinder #8 Misfire
P0309 Cylinder #9 Misfire
P0310 Cylinder #10 Misfire
P0315 No Crank Sensor Learned
P0320 No Crank Reference Signal at PCM
P0325 Knock Sensor #1 Circuit
P0330 Knock Sensor #2 Circuit
P0335 Crankshaft Position Sensor Circuit
P0339 Crankshaft Position Sensor Intermittent
P0340 No Cam Reference Signal at PCM
P0344 Camshaft Position Sensor Intermittent
P0351 Ignition Coil # 1 Primary Circuit
P0352 Ignition Coil #2 Primary Circuit
P0353 Ignition Coil #3 Primary Circuit
P0354 Ignition Coil #4 Primary Circuit
P0355 Ignition Coil #5 Primary Circuit
P0356 Ignition Coil #6 Primary Circuit
P0357 Ignition Coil #7 Primary Circuit
P0358 Ignition Coil #8 Primary Circuit
P0401 EGR System Failure
P0403 EGR Solenoid Circuit
P0404 EGR Position Sensor Rationality
P0405 EGR Position Sensor Volts Too Low
P0406 EGR Position Sensor Volts Too High
P0420 1/1 Catalytic Converter Efficiency
P0432 2/1 Catalytic Converter Efficiency
P0440 General Evap System Failure
P0441 Evap Purge Flow Monitor
P0442 Evap Leak Monitor Medium (0.040) Leak Detected
P0443 Evap Purge Solenoid Circuit
P0452 NVLD Pressure Switch Sense Circuit Low
P0453 NVLD Pressure Switch Sense Circuit High
P0455 Evap Leak Monitor Large Leak Detected
P0456 Evap Leak Monitor Small (.020) Leak Detected
P0460 Fuel Level Unit No Change Over Miles
P0461 Fuel Level Unit No Change Over Time
P0462 Fuel Level Sending Unit Voltage Too Low
P0463 Fuel Level Sending Unit Voltage Too High
P0480 Cooling Fan 1 Control Circuit
P0481 Cooling Fan 2 Control Circuit
P0498 NVLD Canister Vent Valve Solenoid Circuit Low
P0499 NVLD Canister Vent Valve Solenoid Circuit High
P0500 No Vehicle Speed Signal Circuit
P0501 Vehicle Speed Sensor #1 Performance
P0505 Idle Air Control Motor Circuits
P0506 Idle Speed Low Performance
P0507 Idle Speed High Performance
P0508 IAC Valve Sense Circuit Low
P0509 IAC Valve Sense Circuit High
P0513 Invalid Skim Key
P0522 Pressure Sensor Low
P0523 Oil Pressure Circuit High
P0532 A/C Pressure Sensor Low
P0533 A/C Pressure Sensor High
P0551 Power Steering Switch Failure
P0572 Brake Switch #1 Circuit Low
P0573 Brake Switch #1 Circuit High
P0580 Speed Control Switch #1 Low
P0581 Speed Control Switch #1 High
P0582 Speed Control Vacuum Solenoid Circuit
P0586 Speed Control Vent Solenoid Circuit
P0594 Speed Control Servo Power Circuit
P0627 Fuel Pump Relay Circuit
P0630 VIN Not Programmed in PCM
P0632 Odometer Not Programmed in PCM
P0633 Skim Key Not Programmed in PCM
P0645 A/C Clutch Relay Circuit
P0660 Manifold Tune Valve Solenoid Circuit
P0685 ASD Relay Control Circuit
P0688 ASD Relay Sense Circuit Low
P0700 EATX Controller DTC Present
P0703 Brake Switch Sense Circuit
P0850 Park/Neutral Switch Performance
P1115 General Temp Sensor Performance
P1192 Inlet Air Temp Sensor Voltage Low
P1193 Inlet Air Temp Sensor Voltage High
P1195 O2 Sensor 1/1 Slow During Catalyst Monitor
P1196 O2 Sensor 2/1 Slow During Catalyst Monitor
P1281 Engine is Cold Too Long
P1282 Fuel Pump/System Relay Control Circuit
P1289 Manifold Tune Valve Control Circuit (6 Cylinder)
P1290 High Pressure Fuel Shut-Off Solenoid Relay Circuit
P1292 Fuel Pressure Sensor Voltage Too High
P1293 Fuel Pressure Sensor Voltage Too Low
P1294 Target Idle Not Reached
P1296 No 5-Volts to MAP Sensor
P1297 No Change in MAP From Start to Run
P1299 Vacuum Leak Found
P1388 ASD Relay Control Circuit
P1389 No ASD Relay Ouput Voltage at PCM
P1390 Timing Belt Skipped 1 Tooth or More
P1391 Intermittent Loss of CMP or CKP
P1398 Misfire Adaptive Numerator at Limit
P1486 Evap Leak Monitor Pinched Hose Found
P1489 High Speed Fan Control Relay Circuit
P1490 Low Speed Fan Control Relay Circuit
P1491 Cooling Fan Relay Control Circuit
P1494 Leak Detection Pump Switch or Mechanical Fault
P1495 Leak Detection Pump Solenoid Circuit
P1496 5 Volt Supply, Ouput Too Low
P1593 Speed Control Switch Stuck
P1595 Speed Control Solenoid Circuits
P1596 Speed Control Switch Always High
P1597 Speed Control Switch Always Low
P1598 A/C Pressure Sensor Volts Too High
P1599 A/C Pressure Sensor Volts Too Low
P1602 PCM Not Programmed
P1603 PCM Internal Dual-Port Ram Communication
P1604 PCM Internal Dual-Port Ram Read/Write Integrity Failure
P1607 PCM Internal Shutdown Timer Rationality
P1683 Speed Control Driver Circuit
P1861 Siphon Line Disconnected
P2008 Short Runner Solenoid Circuit
P2066 Fuel Level Sensor #2 Performance
P2067 Fuel Level Sensor #2 Low
P2068 Fuel Level Sensor #2 High
P2074 Manifold Pressure/Throttle Position Correlation - High Flow/Vacuum Leak
P2096 Down Stream Fuel System 1/2 Lean
P2097 Down Stream Fuel System 1/2 Rich
P2135 TPS #1 AND #2 Voltage Correlation
P2302 Ignition Coil #1 Secondary Circuit- Insufficient Ionization
P2305 Ignition Coil #2 Secondary Circuit- Insufficient Ionization
P2308 Ignition Coil #3 Secondary Circuit- Insufficient Ionization
P2311 Ignition Coil #4 Secondary Circuit- Insufficient Ionization
P2314 Ignition Coil #5 Secondary Circuit- Insufficient Ionization
P2317 Ignition Coil #6 Secondary Circuit- Insufficient Ionization
SPEED CONTROL
P1683 Speed Control Power Relay; or S/C 12v Driver Circuit
TRANSMISSION
P0120 Throttle Position Sensor Signal Circuit
P0122 Throttle Position Sensor/APPS Low
P0123 Throttle Position Sensor/APPS High
P0124 Throttle Position Sensor/APPS Intermittent
P0218 High Temperature Operation Activated
P0562 Low Battery Voltage
P0604 Internal TCM
P0605 Internal TCM
P0613 Internal TCM
P0700 Internal TCM
P0705 Check Shifter Signal
P0706 Check Shifter Signal
P0711 Trans Temp Sensor, No Temp Rise After Start
P0712 Trans Temp Sensor Voltage Too Low
P0713 Trans Temp Sensor Voltage Too High
P0714 Transmission Temperature Sensor Intermittent
P0715 Input Speed Sensor Error
P0720 Ouput Speed Sensor Error
P0725 Engine Speed Sensor Circuit
P0731 Gear Ratio Error in 1st
P0732 Gear Ratio Error in 2nd
P0733 Gear Ratio Error in 3rd
P0734 Gear Ratio Error in 4th
P0735 Gear Ratio Error in 4th Prime
P0736 Gear Ratio Error in Reverse
P0740 Torque Converter Clutch, No RPM Drop @ Lockup
P0743 Torque Converter Clutch Solenoid/Trans Relay Circuits
P0748 Pressure Solenoid Control/Trans Relay Circuits
P0750 LR Solenoid Circuit
P0751 O/D Switch Pressed (Lo) More Than 5 Minutes
P0753 Trans 3-4 Shift Solenoid/Trans Relay Circuits
P0755 2/4 Solenoid Circuit (41TE, 42LE)
P0755 2C Solenoid Circuit (45RFE)
P0760 OD Solenoid Circuit
P0765 UD Solenoid Circuit
P0770 4C Solenoid Circuit
P0783 3-4 Shift Solenoid, No RPM Drop @ Lockup
P0841 LR Pressure Switch Sense Circuit
P0845 2/4 Hydraulic Pressure Test Failure (41TE, 42LE)
P0845 2C Hydraulic Pressure Test Failure (45RFE)
P0846 2/4 Pressure Switch Sense Circuit (41TE, 42LE)
P0846 2C Pressure Switch Sense Circuit (45RFE)
P0867 Line Pressure Fault
P0868 Line Pressure Low
P0869 Line Pressure High
P0870 OD Hydraulic Pressure Test Failure
P0871 OD Pressure Switch Sense Circuit
P0875 UD Hydraulic Pressure Test Failure
P0876 UD Pressure Switch Sense Circuit
P0884 Power Up at Speed
P0888 Relay Output Always Off
P0890 Switched Battery
P0891 Transmission Relay Always On
P0897 Worn Out/Burnt Transaxle Fluid
P0932 Line Pressure Sensor Fault
P0944 Loss of Prime
P0951 Autostick Sensor Circuit
P0952 Autostick Input Circuit Low
P0987 4C Hydraulic Pressure Test Failure
P0988 4C Pressure Switch Sense Circuit
P0992 2-4/OD Hydraulic Pressure Test Failure
P1652 Serial Communication Link Malfunction
P1684 Battery Was Disconnected
P1687 No Communication with MIC
P1694 BUS Communication with Engine Module
P1714 Low Battery Voltage
P1715 Restricted Port In T3 Range
P1716 BUS Communication with Engine Module
P1717 No Communication with MIC
P1726 UD Hydraulic Pressure Switch Circuit
P1727 4C Hydraulic Pressure Switch Circuit
P1728 2C Hydraulic Pressure Switch Circuit
P1732 UD Pressure Switch Sense Circuit
P1733 4C Pressure Switch Sense Circuit
P1734 2C Pressure Switch Sense Circuit
P1735 Inadequate Element Volume 4C
P1736 Gear Ratio Error in 2nd Prime
P1738 High Temperature Logic Activated
P1739 Power Up at Speed
P1740 TCC O/D Solenoid Performance
P1756 Governor Pressure Not Equal to Target @ 15-20 PSI
P1757 Governor Pressure Above 3 PSI In Gear @ 0 MPH
P1762 Governor Pressure Sensor Offset Volts Too Low Or High
P1763 Governor Pressure Sensor Volts Too High
P1764 Governor Pressure Sensor Volts Too Low
P1765 Switched Battery (41TE , 42LE)
P1765 Trans 12 Volt Supply Relay Control Circuit (42RE, 46RE, 47RE)
P1767 Relay Output Always On
P1770 Inadequate Element Volume LR
P1771 Inadequate Element Volume 2C
P1772 Inadequate Element Volume OD
P1773 Inadequate Element Volume UD
P1775 Solenoid Switch Valve Latched in TCC Possition
P1776 Solenoid Switch Valve Latched in LR Position
P1781 OD Pressure Switch Sense Circuit
P1782 2-4 Pressure Switch Sense Circuit
P1784 L-R Pressure Switch Sense Circuit
P1787 OD Hydraulic Pressure Switch Circuit
P1788 2-4 Hydraulic Pressure Switch Circuit
P1789 2-4/OD Hydraulic Pressure Switch Circuit
P1790 Fault Immediately After Shift
P1791 Loss of Prime
P1792 Battery Was Disconnected
P1793 TRD Link Communication Error
P1794 Speed Sensor Ground Error
P1795 Internal Transmission Controller
P1796 Autostick Input Circuit
P1797 Manual Shift Overheat
P1798 Worn out / Burnt Transaxle Fluid
P1799 Calculated Oil Temp In Use
P1899 P/N Performance
P2700 Inadequate Element Volume LR
P2701 Inadequate Element Volume 2C
P2702 Inadequate Element Volume OD
P2703 Inadequate Element Volume UD
P2704 Inadequate Element Volume 4C
P2706 MS Solenoid Circuit
Got the problem resolved it turns out it was a bad tcu relay it was intermittent the coil would energize and operate properly for a short amount of time then the coil in the relay would burn out shut down the solenoid pack and kick the tranny into limp mode!!!! new relay no problems thanks for the help.
Check your relay wires:
green/black: signal from the tcu +12 with the key on.
Black: ground constant.
Red:+12 constant
Red/Black: +12 when the relay is active (with key on)
