Hey guys. So Ive been looking around for a cruise control to non cruise control write up with pictures. I haven't found one (maybe I didn't look hard enough) so I decided to make one. This is my first write up so feel free to critique me, any information helps. Thanks
This mod was done on a 1992 Mitsubishi Eclipse GSX
Cruise Control to Non Cruise Control Removal/ Installation.Using Non Cruise Control cable: Part# MB539465
Step 1: This is what your motor should look like with cruise control installed. The cruise control unit is mounted on the fire wall along with the cables.
Same shot just wider angle.
Step 2: Remove the cover on the cruise control unit. There are 2 bolts on either side of the box. When removed, pull it off.
Step3: Find where your throttle cable is hooked onto your throttle body. Pull the cable out of the throttle body groove and push the cable out.
Step4: Remove the 2 bolts holding the throttle cable bracket on to the intake manifold.
Step 5: Unbolt the two throttle cable holders. They are the two metal clips, also attached to the intake manifold.
Cable Holding Bracket.
Both brackets unbolted.
Step 6: Back to the cruise control box. There are 3 bolts bolted into the fire wall. The bolts are in a triangle pattern. You are able to see the top bolt in the picture. Unbolt them now. When they are unbolted, unhook the wiring connector to the electrical cruise control unit.
3 Bolts Unbolted
Connector
3 Bolts Unbolted
Connector
