Removing baffle from valve cover?
My catch can setup I picked up of the link forum. Proven to be plenty "proper" for 9 sec cars with baffles in so I think I'll stick with it :rocks:
Does anybody have any pictures from the under side of the valve cover after installing the -10 fittings? It seems like if you place them over top of the existing spots about half of the fitting will be below the baffle and the other half would be above.
Is that how you guys the kept the baffles are running it?
Also on the back side did anybody grind away some material so the fitting would sit flat?
Also if anybody has more pictures that'd be much appreciated!
I'm just trying to do everything I can myself so when I bring it to my local shop all they have to do is weld on the fittings for me.
what do you guys think about custom 1mm SS baffle like this?
Looks great. have one made and see how it fits
the main question is about these oval holes, are they OK and if it's enough or is it too much? :)
that's why I think 1mm thick stainless steel should be OK there
the only question is how, where and what shape holes to make in places where the evap. gas recirculates?
here it is...
do you guys think it should work fine, I mean this kind of SIMPLE shape/design? :)
    • eclipsemf
