Any idea if this works on evos (or DSMs using evo ecus)? I assume that an evoscan cable will work just fine since an openport 1.3 cable will work or am I wrong? Do you need to have the second port connected or is that only for reflashing?
Otherwise I am very pleased with the idea of this even though I wont be able to play with it until spring.
