Boostjunki84
- 774
- 5
- Oct 12, 2007
Candler,
North Carolina
I got to see FenixTX717's kit, actually unwrapped it, and I was pretty impressed. 1/8" NPT fittings and bungs welded into the piping and each flange was thick. As stated, packaging was VERY good and from what I've seen customer service is top notch. IMO a good bang for the buck kit.
The core is nothing "special" but I'm sure it will get the job done. Slightly offset style external fins but straight through internal.
Although it's not a short route style, I still like the fact there aren't any 90* end tank inlets or outlets.
This is a short-route kit; mind you it does not take the same route as other kits. However, this kit is a complete bolt on. You do not have to cut or relocate anything on the car. I do know with the SSAC kits, you have to cut through some of the frame, on each side of the radiator. I'm not sure that the few inches of extra piping will make that big of a difference between the two.
It is indeed a short route compared to the Greddy, Apexi or stock styles. Believe me, I had the Greddy, and it was a ton of pipes.
As for the kit itself, for a street kit, I'd run it if I'm trying to save a buck. If not, like my car now, I wouldn't run it at all. And I agree with what Gamble was getting at before. With so many pipes with couplers, it increases the chances of boost leaks. It's not if a person can assemble a damn clamp on a pipe, it's if those clamps will hold a constant pressure for 'X' amount of time. This is one of the reasons I went with my ETS Ultra short kit. In my kit there are seriously 3 short pipes and a TB elbow all with 4ply couplers and T-bolts all around. There aren't any filler pipes, it's all welded where it needs to be and couplers where they need to be for ease of installation as well as maintanence.
Another small gripe I have. If a company is releasing a new product, and this goes for ANY company making any product, there should be some sort of testing done by the maker of it. Yeah, all the distributors go out and test a lot of the stuff, but it shouldn't be up to them to do it. I believe in companies that are upfront with product information. If not, this just turns into a modification a ricer would use. "I don't know if it adds horsepower over my stock piece, but it sounds/looks SO COOL!"
These pipes connecting points are located in places which can all be reached, even when the bumper cover is on the car. The PR kit also has one more pipe than the ETS kit you have and also has 4-ply couplers and t-bolt clamps all around. It's not worth it for me to pay $600+ more for one less pipe, have to trim body work, and according to the ETS website, seems to have SS piping; the PR kit has all aluminim piping.
Also of note, is the PR kit also comes with the ability to use a 14b/16g turbo or a downflow turbo; so if you have a 16g now and want a bigger turbo all you have to do is swap out one pipe. Again, all the couplers and clamps are provided for this. I do realize that ETS offers a "steet kit", which offers the same abilities, but is still almost $400 more than the PR kit is selling for right now and has a smaller IC.
As for testing, I spoke with Tim about going ahead and buying this kit, installing it, and testing it. Personally, I don't know how it will perform yet, but stay tuned and I promise I will keep everyone posted.
I never did find the directions that were said to be provided, so I contacted Tim via e-mail. He responded that they were still in the works and will be included soon. I was also wondering about the extra brackets supplied with the kit, as I could not figure out where they were supposed to mount. Tim told me they were provided to be used for additional support for the IC, if the customer felt like it was needed. I do not think they will need to be used, but i'm looking at mounting a couple to see if the additional support makes a difference.
