Went Snowoarding over he weekend.... got compressor surge around 3500ft
ApexVIII
812
5
Jan 12, 2008
Modesto, California
anyone else have this problem?
i have a 1g bov, that is crushed a little. im gunna try an uncrushed one next time
but i did have this problem in my Evo when i went to Kirkwood one time
i am at 8ft above sea level, with about 21/22 vac at idle
when i got to the resort(4500ft maybe?) i was at about 15 vac at idle
any ideas?
and it only surged at 3500 ft?
no it started around 3500ft, so like 3500ft+
yea idk my friend never had any problems with his STi(i know different cars )
another friend has a 1g bov but uncrushed and he has no problems...
it was pretty bad the car would surge and buck
"Compressor Surge" doesn't refer to the car itself surging. I'm pretty sure what you experienced was just a change in tuning caused by the change in air density.
No this is for sure compressor surge,
it makes that chipmonk sound LOL and when the turbo is surging it is causing the car to buck
this is exactly what is sounded like
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/LZUbo_mNDZM&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/LZUbo_mNDZM&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
That video does not display compressor surge.
Compressor surge occurs under boost- NOT under vacuum. The car in that vid simply has too much blow off valve tension for the low (7 psi) boost they are running. What you are hearing is blow off valve flutter- the airflow is trying to force it's way out of the valve, but the high spring tension is not letting it. This is basically rendering the function of the blow off valve to be useless by keeping too much pressure in the piping, and will eventually damage the turbo.
My buddy's Powerstroke Diesel used to surge a lot when he would lug the engine down in a higher gear. The turbo would be making full boost (somewhere around 28-30psi) at an RPM where the engine couldn't make use of the airflow the turbo is producing. The pressurized air would back up in the piping, and you would hear a sound through the intake that sounded much like the blow off valve on the car in that video, only it would happen under boost, like this:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/evGFfuhUaRM&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/evGFfuhUaRM&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
...and this vid, of a Skyline with horrible surge:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/nCj6Spwl1CU&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/nCj6Spwl1CU&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
If what you're hearing is blow off valve flutter, your valve's tension is simply too strong for your boost level.
What did your boost gauge do when you left off the gas? Anything out of the normal as in where the needle drops to?
A lot of the time, comp surge like that is from the BOV spring being too stiff. Seeing as it's a 1G BOV, it could be just a little too stiff since it is crushed. Please, do try using an uncrushed BOV next time and see what happens. If it was a Greddy or a HKS there shouldn't be any kind of problem because the Greddy can be adjusted for spring stiffness and the HKS is a different setup.
My question: Can someone do a quick explanation on why an altitude change, as well as a idle Vac change, would effect spring stiffness. I can grasp the gist of it but not in terms that would make sense to other people :coy:.
It is compressor surge. Without the valve opening you are getting 0 flow at high pressure levels, which is always past the surge line. Surge can, and does, occur under vacuum.
Even with it being crushed somewhat, it shouldn't do that. What boost levels did you try it at?
BoostFrenzy, it's that the amount of vacuum trying to overcome the spring tension is less, so less spring tension is needed to get a decent blow off point.
When I had C.S, I took of my 1g BOV and check if something was blocking it. I found some electrical tape that covered 3/4 of the flange hole.
Check and see if you have something blocking it or even check the vacuum line from your intake manifold to your BOV is still there or if its kinked and what not.
P.S: In one of your vids, I hear all that remains in the background..keekee!
in one of my video's? LOL
well it happened most of the time when i was in 5th gear, i would build a little boost to keep speed up hill and then when i let off it would surge,
i just bought a uncrushed 1g bov so we will see if that helps i am hoping it does.
I agree with the other member, the video of the car suppossedly "compressor surging" with the hood off, was indeed not "compressor surge". That was blow of valve flutter, many people confuse the two. Easy way to tell the difference......BOV flutter occurs when letting off of the throttle, which lets the valve let off and you hear the noise. Compressor surge occurs under load, such as open throttle and accelerating.
Um the very first video is compressor surge. Its caused by the BOV being to tight and not letting all the compressed air and and forcing it back into the housing.
Either way both are bad for Turbos.
Very true, my bad on that one. I just recently learned that the can be two different types of compressor surge. But the only difference is the bov fluttering and doing what you said causes one. And your engine not being able to use all the air the turbo it putting out, so it backs up into the housing would be the other one. That definitely helped though, thanks. Plus I agree 100% on it being bad for a turbo :thumb:
I personally don't consider it "surge" unless it's happening under load, although a poorly-functioning BOV will cause air to back up in the piping under vacuum in a way similar to surge happening under load....there's just nothing continually driving the compressor wheel when it happens under vacuum.
I'm trying to fine tune my bov I'm afraid of getting compressor surge. I have a cheap ebay turboxs knock off. It has a weak spring in it so it has 6 washers in it...If i take all washers out the car will die after i let off the gas after full throttle. But I'm afraid if I have to many in it I will get compressor surge. As it is right now with 6 washers in it it holds all 15 psi I have, when im at a low rpm like 1500rpm's at wot and i let off the gas it will still flutter at that low of an rpm. Can someone guide me through this?
:dsm:
Sure...scrap the knockoff RFL and get a 1G valve, then hook it up to recirculate as it's intended. No tuning required, no need to worry about the car stalling between shifts or surging at low boost.
You own a knockoff of the RFL which, even in Genuine form, is probably the worst BOV on the planet. It's designed for Honda guys who are running 6psi to make some noise so they think their car is fast.
Using a BOV that is held in place by three set screws is asking for trouble.
yea those are very crappy BOV's
get a 1g
my car sounds just like that SR20 if I boost less than 5psi, and if your listening under the hood and rev the car up, the flutter sound is coming from the intake pipe and air filter area, not from the UIC pipe, so wouldnt that mean the air is blowing back through the turbo, wich is generally not good? and isn't that a form of compressor surge? BOV is not recuirc'd either and there is no sound from there at all when it happens. Anything over 5 psi functions as normal, so basicaly reving in nuetral does the flutter best.
Isn't the video with the skyline Turbo Stall? Turbo stall usually is an imbalance of psi between compressor side and turbine side and when when the force in turbine side isnt strong enough to drive the comp side, it stalls out making a "surging" sound
  • For sale 1g 90 Oil Cooler
    • kyler021
