Thanksgiving Run~ Renton
My buddies Talon is still down and he really wants to go. Anyone got a good 6bolt they wanna sell?
Blk window I saw you s2000 at the track I think. What was your fastest time? My friend Ryan with a black type r was telling me bout it. Jack, me you and kyle are bout to be doing some pulls before then. Hopefully Ryans car will be ready too.
Basically, Ryans Integra is about to be an effin beast and I'm not too confident about freeway racing that mofo... But 1/4 milein I'll eat his ass for breakfast :)
1. Jack (Lccynmbr13) 2g GSX
2. Zak (DSM Zak) 1g GSX
3. debow 8787 90 tsi awd
4. blkwidow 99 gst spyder
5. thumper32k 95 GSX
6. woooop
7. OneLove 97 GSX
8 GSTEclipse99 99 GST
9. Alex (Lazy12g) 96 Tsi AWD
For those of you already listed are all of you planning on Dynoing? If not please let me know. If you do plan on dynoing BRING CASH! I'm not sure if Andre will be there or not and I don't have access/ know how to use the card machine.
From here out anyone else planning on being added to the list specifiy whether or not you plan on making dyno runs. THANKS!
as of now i wont be dynoing i am all stock and i think my ECU is ####ed it still works but is having problems
Nah it wasn't me. I've never been to pacific raceways since I've got here for some reason.
I have one, PM or call me.
206 920 2555
Thanks man I just gave him your number. His name is Brent.
There was a crazy A$$ S2K at the track with a big FMIC hauling some booty.
Dude seemed pretty chill, I complimented the car, and damn did it sound good.:sneaky:
add me to the list... i'll be there for the meet and cruise.
by chance when are we meeting up at pina at??
i'll get some other close dsmer's and see if they wanna go to. post it up on myspace :) LOL.
add me onto the list :)
anyone have idea's on what i should do to make my project gsx galant into a VR4 turbo?
6. woooop
7. OneLove 97 GSX
9. Alex (Lazy12g) ***95*** woah damn!!! Tsi AWD
10. crazy 1gb 94 Laser N/T
11. Ryan 2001 Acura Integra Type R Turbo (and I don't wanna hear any flaming this things badass)
As far as the time we'll meet up at Pina... I'll be there at 10 getting the dyno set up and ready to rock I don't care if you all want to show up then or later. I highly suggest anyone who plans on dynoing shows up around 1030 or so in order to get us done early enough to still eat and go on a drive. In the past racking, wiring in boost lines, calibrating the dyno, making pulls and unracking has taken usually 20 minutes to a half hour per car given the vehicle doesn't break on the dyno.
TIPS FOR BRINGING YOUR CAR TO DYNO
1. CHECK YOUR FLUIDS! This includes oil, coolant, and gear oil (tranny fluid for you at guys) We'll double check your oil level and coolant resevoir prior to dynoing but to speed the day up everything else on that level will be up to you.
2. Check your tune. As this is a dyno day we won't be checking any factors in the tuning process for you. If you want to make a good number you'll need to have your car dialed in prior to getting on the dyno. These aren't tuning sessions we're just making pulls to see what numbers you're making there will NOT be time to play with your SAFC, DSMLink, AEM, or whatever else you may be using for tuning.
3. Check your tire pressure. The Dyno Dynamics dyno seems to like alot of pressure in your tires. For the best reading and to prevent spinning on the roller have your tires at about 40 psi or if your tires have a max psi rating less than that max them out.
4. Fix your exhaust leaks. Our wideband will be stuck in your tailpipe. This means any leaks before the muffler will change the actual reading of your AFR. (note that having a catalytic converter will also give a false number on the wideband)
For directions to the shop mapquest
PINA Motorsports
O'Brien Commerce Center
7405 S. 212th St. Suite 123
Kent, WA 98032
i'll bring some other dsmer's with me. what time r we meeting up for this at for pina?? anyone wanna see a RWD TSI?????????????? yes i really mean RWD!!!
  • For sale 1g 90 Oil Cooler
    • kyler021
