fast90eclipse
- 227
- Jul 3, 2007
OLYMPIA,
Washington
ok i did a complete timing belt service. just for the fact of my balance shaft belt broke an wedged the balance shft belt next to the crank so it bent the sheet medal plate behind the crank sprocket. bent the plate back somewhat straight. put new balance shaft tensioner on along with a new timing belt tensioner too. aligned the marks a put it all back together an fired it up an now i got vibrations on the lower end.now my question is when the balance shaft belt when did the balance shaft break inside or what.### if i start it up an back it out the driveway an start taking off i automatically start to get vibrations.so do i buy the balance shaft elimination kit or is something else at fault????
