View Single Post
Old 08-18-2008, 10:24 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #38 (permalink)
JayRolla Offline
Proven Member
JayRolla's Avatar
Tech Posts: 4,647
Classifieds Rating: 6
Reputation: JayRolla is extremely helpful and trustworthyJayRolla is extremely helpful and trustworthy
Well had a bad experience today with the Talon. I was WOT in a high gear and my drive shaft decided to completely twist on me, which caused it to bend and pull from the transfer case. Then it dropped hit the ground and ripped the center bearing out from the chassis!!!
This was a custom 2 piece drive shaft made from a mighty max shaft I believe. It was balanced just fine also. I wonder if that wreck I got in a few months back may have caused this. Weird thing is it was while under WOT and not when shifting. Hopefully I can just replace the shaft and be ok.
____________________________
Jason~6bolt/4bolt E316G@32psi, ECMlinkv3, Corn Fed
