The Sexy Grandma 15 day build
Status
Not open for further replies.
Sounds like a bit of work still left.......keep up the good work!
And yes at BOTI they are quite strict on tech ask me how i know ROFL
I believe you would be in the Pro Import class like Jake M. so i believe it will take 8.60ish ET's to be competitive.....hopefully you don't experience the same drivetrain problems like Jake :thumb:
Yeah pistons taking out aluminum rods no bueno:notgood:
So what have u guys decided for fuel? Im seriously considering magnus' mechanical fuel pump drive kit w/ a couple of their rails for my 90gsx build. Im starting off with a bw s368 but i want the fuel system to handle whatever i bolt up to the t4 topmount. Im just starting on my build so i still have a long way to go but the parts are already piling up. Im really looking forward to seeing how your car turns out. Any plans of comin out this way, maybe to bandi in colorado?
-wes
Holy shit WTF
The driveshaft flopping around at 80+mph is no fun what so ever. Ugh, we have had such a bad season with breaking parts, but we are pushing the car to try and keep up with the big GM pro-teams that are running 8.20's-8.40's in my class, everytime we step it up to try and hang with them something breaks.
The driveshaft breakage was on my 1st round of eliminations, that was the 1st time I have gone out the 1st round in over 8years. And to break against a god damn mid 10sec honda to boot. That was not a good day.
I am however in 3rd place in points for Pro-import class so we must be doing something right:thumb: Points
Ok back on topic, lets not talk about my turd, this is fst91dsm build thread and lets keep it on topic.
-wes
We have a JM Fab Fuel Cel, Aeromotive A1000 Fuel Pump, a couple of fuel filters -10an Feed Lines, 1600cc injectors, -8an return lines. Were going to stay up here in the NW this year, or whats left of it, LOL. Next year there is a good possibility of some long road trips with the car however.
Just a word of advice about the A1000 pump. I have the same pump you are running and I am running out of fuel pump at 42lbs, about 40lbs it starts to drop a bit of pressure and 42lbs it's dropping 7psi of pressure. They don't like to be ran above 85psi from my experiences with it.
You can however put a band aid on it and use a kenne bell boost a pump and add more voltage to it and get a little bit more flow and it will allow you to run a tad more fuel pressure as well, but again that is just a band aid.
Or you can sell your A1000 and get the eliminator pump, that pump should be enough for what you wanna do.
I might wanna add this is at 98-100% injector duty cycle with my 1600cc's
You should both look into the new FIC injectors coming out. They suposedly fixed the mid throttle and cruising problems and the new style has alowed them to have like 1850cc injectors or something nuts but they are suposed to cost 500 when they come out.
Not that either of you car about cruising or part throttle part LOL
What's funny is you broke cruised and made it look like a good race ROFL
Thanks Jake. Im sorry to hear about all of your misfortune this year. Hopefully well be able to line up against eachother at least once by the end of this year.
No problem man, and as far as all the misfortune, thats racing, and at this power level it's expected. Just sucks when it does happen.
We got a couple of things we are going to try in Seattle to keep this turd together, so we shall see.
Ive been thinking about the jmfab fuel cell but the fact that it doesnt have any type of bladders is whats holding me back. My car isnt goin to be a dedicated dragcar, it would still some occasional street use
-wes
-wes
It is true that there is no bladder but I would have no problem running the cel 100% of the time as a street car. If thats the only thing holding you back, dont let it. :thumb:
It looks like we will have a few events this year at our track here in Spokane.
Here's the schedule in case you didn't know?
Aug. 30th
Sept. 13
Sept. 20
Sept. 27
It would be a good place to test plus I would love to see it run again!!!;)
Aug. 30th
Sept. 13
Sept. 20
Sept. 27
Thats awesome, I had no idea the track up there was open again this year, if ever. We will for sure be making a trip up. My guess is either the 13th or the 20th.
Yeah it broke right in front of me LOL
Some more work got done today on the car. We got the Ice Box mounted and the lines run to the water pump for the air to water intercooler. Also we got the fuel pump mounted and have the line from the sump to the fuel filter and fuel pump taken care of too. Ill get some pics of it up tomorrow.
Here are some pics of the progress from yesterday...
the car is looking amazing! Im dying for my parts to come in so that i can actually do something besides tearing the car apart...my body man has been working hot and heavy on mine and told me yesterday that the car should be ready to prime by the weekend...id post pics, but nobody wants to look at a stripped gsx..hahah...looks good man, keep the pics coming.
-wes
Status
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
