gsx ftw
- 105
- 1
- Jan 5, 2008
510/408,
California
So I got my Dynatek ARC-2 today from STM. It comes with the wiring harness and setup looks like it'll be a breeze. I had one concern though...
In the instruction manual, it describes how to set up the two-step. There is a broken circuit, and upon closing the circuit, the 2-step is activated. My question is...is there a way to hook up the 2-step to the factory clutch switch, while having the switch disabled so I can still start without depressing the clutch pedal?
Also, I believe I have the diagrams all right, but just some concerns. Is the wiring harness provided long enough to get to the coilpack coming from the mounting position on the driver-side front shock tower? Also, where does the black box plug into? How do I wire the fuse into the power line from the battery to the CDI unit? Thanks.
